2 members (Hotrod Lincoln, 1955 1 Series), 231 guests, and 1 robot.
Topics128,113
Posts1,056,279
Members48,439
AD Addict & Tinkerer
I just rebuilt my Rochester type B carburator on my 1952 3100 with a 59 235 installed and noticed two rectangular holes in the air horn. These holes lead directly into the fuel bowl with no filtration. I suspect they may be associated with the oil bath filter that was replaced with a paper air filter by a previous owner. I am curious as to what the purpose of these rectangular holes are for. Any ideas
Phil
Project Journals
Stovebolt Gallery Forum
2 Offline
those are vents, to ensure that the fuel around the floats is at atmospheric pressure
see attached photo
2 Offline
more details to why vents were added
attached
-s
Venting the bowl to the A/C interior also prevents mixture from changing due to dirty air filter element.
Thanks for the info! It seems to me that the vents would allow dirt, water and other debris to enter the fuel bowl. Doesn’t sound like such a good solution. Thanks again!
Phil
Project Journals
Nice find, 2MT!
I like the directions on how to drill a vent hole to upgrade older model carburetors.
There have been a lot of posts about "empty bowls at startup" which might be solved by this fix.
Carl
thank you great information
1953 Chevy 3100
261 and SM420
53Chevy 3100
1953 Mack Firetruck
1972 Porsche 911
1986 Honda Goldwing
