| | | Forums66 Topics128,142 Posts1,056,490 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 29 Member | | Member Joined: Dec 2003 Posts: 29 | well, i was talking with a freind over the weekend, and i think i found a 454 for cheap (read $100). i have a few questions. first, my truck is a 59 1-ton. i have heard that the 1-ton frames are narrower, but can somebody confirm this?
i was looking at the dakota IFS from industrial chassis, does anybody have any experience with this setup? can you just buy the crossmember, and then buy a f'ed up dakota and use the components of ot it?
thirdly, how do i mount the 454? does the crossmember for the dakota kit have a crossmember that will hold the engine? if not then how do i moun this thing?
'59 Chevy 1-ton '03 **** Lightning '96 Kawasaki 1100 zxi
| | | | | Joined: Dec 2001 Posts: 58 Member | | Member Joined: Dec 2001 Posts: 58 | I have a dakota set up in my 57 1/2 ton with a bbc and I love it. All you buy is the crossmember, the rest is junk yard stuff. I C has weld in mounts for most engines too. What you end up with as a truck front end with big brakes, and a choice of 5 or 6 lugs, that is the correct width for way less than the cost of any other front end out there. | | | | | Joined: Apr 2004 Posts: 36 Member | | Member Joined: Apr 2004 Posts: 36 | Richie Z
I chatted with you about the Dakota front on a different forum. Called them up and talked for a while about what I wanted. Nice guys. They were tossing around the possibility of doing a current model Dakota conversion, Which would make the long travel suspension I want a lot easier. I'll have to call them back soon and see if they ever pursued that.
Larry | | | | | Joined: Oct 2003 Posts: 12 Member | | Member Joined: Oct 2003 Posts: 12 | Richie, i also have a 57 half ton, i like the idea of the dakota crossmember, but what did you usee for a rear end?...i'd like to keep the same bolt pattern. Is the dakota rearend wide enough? | | | | | Joined: Apr 2004 Posts: 36 Member | | Member Joined: Apr 2004 Posts: 36 | Chopped top
An early 9" F-ord or an 8.8 out of a Mustang V8 if you want one a little narrower [bigger tires] will give you a 5 on 4 1/2 just like the Dakota.
Larry | | | | | Joined: Dec 2001 Posts: 58 Member | | Member Joined: Dec 2001 Posts: 58 | My truck is a pro street deal with a narrow 9" **** rear and a four bar with coilovers. It would seem that if the front end width was correct on the Dakota for a tri five, the rear would have to be very close too. But a word of caution, Dakota rears are soft, probably the worst thing on the truck. I would look for a Torino style **** rear with a 5-4 1/2 bc. Don't forget, later 6 lug rotors will fit early spindles on Dakotas which opens up a whole bunch of options for rears. Hope this helps. Richie Z | | | | | Joined: Dec 2001 Posts: 58 Member | | Member Joined: Dec 2001 Posts: 58 | Hey Chop, I just noticed, were neighbors, I am in Binghamton | | |
