5 members (Rich'sToys, J Lucas, Charles in CA, Stovebolt48, 1 invisible), 95 guests, and 1 robot.
Topics128,151
Posts1,056,994
Members48,460
So I finally got the truck. Insurance stuff is still in the works but it's here.
I've had about 2 hours with the truck since yesterday but I can't figure out what this thing is. Air parking brake?
Spartan
Hoka Hey!
Spartan
1959 Chevy Spartan 100 "Battle Wagon"
2008 Buell Lightning "War Horse"
Great you got the truck! Glad it got there at least mostly ok.
Someone here will know all about the lever.
So, the truck is a wrecker?
~Charley
1954 Chevy 3100 with 235
“Bud”
Follow along in the DITY
1963 Chevy half ton stepside short box 230
1954 GMC 3 ton 302
And several more Chevy camper and work trucks 1979 1987 1996
Hand valve for air trailer brakes.
•1952 Chevrolet 3800 pickup
---All pictures---
I’m guessing you could operate it with your knee?
Thanks Grigg, Basically I will probably never use it haha.
Spartan
Hoka Hey!
Spartan
Yep its a wrecker allright. Its got an old garwood mechanical winch from an old Duece on the back, this this was built to yard out some pretty beefy rigs. The snatch block must weigh 70 lbs!!
Spartan
Hoka Hey!
Spartan
Big Bolt Forum Moderator
glad you got it home!
Mike
Yes, thanks for the response, Spartan.
I just went back through the accident posts. Sounds like you might come out real good.
I sure agree the rear damage is likely just sheet metal .
That is just one beautiful truck!
And Idaho is an excellent home for it.
It sounds like you are taking off the winch set up, or will that incorporate into your flatbed?
Charley
~Charley
“Bud”
1954 GMC 3 ton 302
Thanks Mike me too.
Charlie
My plan is to take the winch off. I wont really need it.
And I'm going to come out alright, I should have enough left over to take care of some of the body work- two small rust spots.
Spartan
Hoka Hey!
Spartan
Also I figured out what the lever was for.
Its actually a parking brake. Maybe thats not what it is supposed to be but thats what it does.
Spartan
Hoka Hey!
Spartan
Not really a "parking brake", it's more like a helper at a tow/recovery scene. The one's I've seen work by stepping on the brake pedal and then pulling the lever down which traps full air to all of the wheels...it's like having a person setting in the cab standing on the brake pedal while you work on the recovery. This wouldn't work as a parking brake as the air pressure might leak down over time allowing the truck to roll away!
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Mike B smile
Mike I didn't think about that. Really good insight. I appreciate it
Spartan
Hoka Hey!
Spartan
H Online: Content
The auxiliary parking brake was called a "Mico Brake Lock" and it was used with hydraulic brakes. The valve in the picture just a trailer brake control that has been repurposed as a wheel lock while winching a load. If you use it that way, keep the engine running to keep the air pressure built up.
Engine would need to be running anyway- winch is mechanical PTO driven. Old Garwood of a Duece.
Spartan
Hoka Hey!
Spartan
