3 members (Nick in Manitou, Hotrod Lincoln, Shaffer's1950), 119 guests, and 1 robot.
Topics128,126
Posts1,056,354
Members48,441
#1300817 02/27/2019 1:48 AM
When the ignition is on, gas gauge pins to full (even when tank has only 5 gallons in it), When I switch the ignition off, the needle drops. What gives? Sending unit? Help...
Try doing a Stovebolt search using the search function in the bar just above your post. Thousands of posts about Gas Gauges. Your answer will be there. Someone will be along soon to save you the trouble.
V
VEW Offline
V Offline
Better for you to do the search, as Martin suggested. I've learned many things about issues other than what I was searching for while doing so; and found solutions to my issue.
But to give you a head start, you have two posts on the back of your gauge, One is 12v with the key on and the other goes to the sending unit on your fuel tank. As your float on your sending unit goes up and down, it increases/decreases the resistance-----which causes the needle on your gauge to move.
Read through the threads will help you diagnose your problem. It could be a number of things: your float is full of fuel, your fuel tank is not grounded, your fuel sending unit needs to be replaced, etc.
Do your search, learn many things that will help you in the future to keep your C10 on the road, and if you run into a problem, let us know. Good luck!
~ Victor
1957 3100 - moved on
What VEW and Horse said. While there are many folks who will give you an answer, there is usually something else going on as well. Please do ask the questions though.
Another quality post.
Real Trucks Rattle
Try this (it is easy and will not hurt anything):
Run a wire from the frame (or, from a ground-strap connector) to a mounting post of the sender on the gas tank.
This needs to be grounded.
If it is not grounded, the gauge will read "full".
Here are better instructions/explanations.
