5 members (1955 1 Series, Wayne67vert, Ponchogl, 3B, Guitplayer), 98 guests, and 2 robots.
Topics128,261
Posts1,058,345
Members48,485
#130080 03/19/2003 3:11 AM
Junior Member
Junior Member
Need a radiator for a 1950 3100 fitted with auto trans. and 350 V-8, any recomendations?
#130081 03/19/2003 4:16 AM
If you can afford it go with an aftermarket one made for the truck . I have an aluminum Afco on my '38 and it does great now that I figured out that my electric fan wasn't working . It didnt do too bad even without the fan working ! I didnt use the radiator trans. cooling ports though , I just used a cooler mounted in front of the rad.
#130082 03/19/2003 7:44 AM
Z
Z Offline
I bought a aluminum 17"x21" I think from speedwaymotors.com for $150That fit fine in my 53'.You would have to run a external tranny cooler (about $30) but why would you want that hot tranny fluid in your radiator anyway?
If you need a tool and don't buy it, you will find you have paid for it and don't have it.
#130083 03/19/2003 11:03 PM
I used a Walker Cobra which is a bolt in. They make a big block and a small block model with the trans cooler. I put the big block model in and a seperate trans cooler for my small block. It doesn't even get up to temp most of the time here in the northeast. Expensive but it worked for me.
