4 members (46 Texaco, Hotrod Lincoln, 2 invisible), 88 guests, and 1 robot.
Topics128,115
Posts1,056,633
Members48,450
Van
Van
Hello,
I did a search on the forums and didnt find anything specific to defrost manifolds and ducting. Mine is missing the passenger side manifold and both ducts. Is this the place for these Questions? Interiors?
Just want to know what yall would use for ducts and which company has the best quality parts and customer service? I'm a bit overwhelmed at how many diff ones there are. I'm new to the forums and we recently bought Our 59 apache swb stepside.
1959 Apache swb stepside
Atlanta Ga.
Van
Van
Anyone?
Atlanta Ga.
Be patient, our interior specialists may be taking a nap. We sure don’t want to wake them up too early.
I bought Vintage air system they provided the tubes for the defroster. Good people my 2 cents to work with. You might look up their components see if that will work. Installing in my 59 Apache 3100!
Pops the truth is out there!
Van
Van
thank you Sir
Atlanta Ga.
Sir Searchalot
Sir Searchalot
I posted an almost immediate quality response. Giving a link for original donor parts and vendor info. No response. Some links go dead and not good to leave on Stovebolt. Also I've had bad luck with new posters with low post count. They don't seem to realize how good Stovebolt is and how fast and complete the responses are.
I also asked what your definition of "manifold" was. Never heard, so was not sure of my info.
So when you are ready to monitor your own post, let me know.
You sure you hit the reply button? I never saw your post and I was watching this thread. Just wondering?
Sir Searchalot
Sir Searchalot
Yes, I watched it for two days (after searching, researching and posting my results) to see if he got the info so I could delete the links or close it out of my watch list.
I have CRS!
Sir Searchalot
Sir Searchalot
grin 10-4.................or as Broderick Crawford would say "2150 to headquarters, I need a chopper". He had that revolver that fired 18 times. I guess I don't have CRS?
Insomniac
Insomniac
bartamos, I saw your post (and it was a quality post). I even followed the links. So, where did it go? ohwell
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Sir Searchalot
Sir Searchalot
I am immature but it's not a medical condition so no Dr. to go to. Just booze.
Van
Van
The manifold I was referring to is the defroster dispertion vent? I ordered one from classic trucks $24.95. It looks like a wide vacuum floor attachment for a small shop vac.
I apologize for not checking here after 5pm yesterday. Had a busy afternoon on phone coordinating an RV rental for an upcoming trip to Florida. I volunteer at the Sun n Fun fly in every year down there for the past 10 years. First year moving up accomodations from a tent to an RV. Wife said so :-)
I have another question about the interior. On the RH kick panel area above the vent is an open square hole. Looks like a cover went there. screw holes in corners. Whats the official name of that cover or what ever goes in there? Its above the vent door area. Looks like an original square hole.
RK
Atlanta Ga.
Van
Van
Does anyone know about that small square hole above the passenger side kick panel vent? Its about 4 inches square.?
RK
Atlanta Ga.
that opening is the fresh air intake for the deluxe heater, see here - for the "lesser" 2 heater versions there was a "delete" plate held by 4 screws to cover the hole
Van
Van
Ahhh Thank you! Now I wonder if this truck originally had the deluxe heater in it. Hmmmm?
Thank you Bill.
RK
Atlanta Ga.
I think the deluxe heater had controls in the dash for defrost/ heat and temp. Th regular heater had a valve under the hood to turn the flow of water off during the summer, and a switch either in the dash or under the dash.
Tommy
59 apache 1/2t
261 short stepside
Van
Van
Well the dash has what looks like an orig smooth cover where the deluxe controls would have been. The ash tray to the left has the same cover. So I'm not sure why the blanking cover is missing unless it was robbed at one point for another truck. Could have been removed to allow more air flow during the summer here in Georgia. N E way I've ascertained an old steel drawer out of a metal cabinet that was headed to the scrap yard to make a new steel blank plate. Hopefully I can make it look stock.
Atlanta Ga.
Moderated by  ndkid275, Phak1
