7 members (MickeyP, David Bush, kades51, Gdads51, cmayna, Donf, 3800GUY),
90
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,702 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2017 Posts: 299 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 299 | I noticed that Jim Carter no longer rebuilds Vacuum window wiper motors. The guy that did it was 92 years old. Does anyone know where or who does rebuild these vacuum wiper motors? | | | | | Joined: Sep 2013 Posts: 1,361 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,361 | Yep, what miraclepieco said. Wiperman did mine 3 (?) years ago and they still work like new.
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
| | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | Wiper man did mine also. No complaints.
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Dec 2014 Posts: 678 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 678 | Wiperman did mine 3 (?) years ago and they still work like new. Wiper man did mine also. No complaints. How much did he charge?
1951 Chevy Panel Truck
| | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | In the link you posted, the ad says $135.00. With free USA return shipping. Click on >what we rebuild<, and the price is at the bottom.
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Mar 2017 Posts: 299 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 299 | SWEET!!! Thank you guy's for this excellent tip. So appreciate this!!
Elmo! | | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | There is a possibility that a cheap simple fix could get a wiper vacuum motor working and is always worth the try.
Remove the vacuum wiper motor, pour or inject approx a couple/three table spoons of motor oil down the vacuum port into the wiper motor. Shake the motor around at all angles in order to get the oil to coat as much of the interior as you can.. Allow it to sit over night. reinstall it and try it.
I did this to my 49 wiper vacuum motor a little over 6 years ago and the vacuum wipers have worked ever since. They didn't work before I did this. To give a little background on my 49, it had sat non-running since 1969.....
It may or may not work for you but giving it a try only costs you a little elbow grease and a little motor oil.
Good luck | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | Did Bob happen to mention what to use as a lube to put in those holes?
| | | | | Joined: Jan 2018 Posts: 298 'Bolter | | 'Bolter Joined: Jan 2018 Posts: 298 | I put a little atf in my 37 wiper motor, left overnight, made sure in was on the intake stroke and sucked the fluid in. Let sit for a while then worked it back and forth. Then hooked up to vacuum cleaner and started slow but after a while it took right off. Works great
1937 GC
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Bob might have mentioned a lubricant, but I cannot find the complete article. It was in This Old Truck or maybe in Pickups 'n Panels In Print. This write-up suggests Marvel Magic Mystery OIl. Brake fluid is also mentioned - the grade is not specified (BUT - damage to paint might occur). | | | | | Joined: Dec 2018 Posts: 5 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 5 | I once had a customer with an early jeep pickup with vacuum wipers. Added a vacuum can (size of a coffee can) from a ford sedan with hidden headlight doors. It was more than enough vacuum to keep the wipers running at a steady speed. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Mar 2017 Posts: 299 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 299 | Now I'd like to know, is the vacuum motor held in place by one or two brackets. Does anyone have a picture on how the motor comes out from underneath the dash. It's so hard to see under the dash.
Thank you in advance, again Elmo | | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | Logic tells me disassembling the motor followed by a through cleaning inside and out, and then applying some oil type lubricant inside might have a high rate of success. Off to Ficken if that doesn’t fix it.
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | The issue with disassembling the motor is that you will likely tear the the very narrow and thin gasket. They crumble very easily and making a new one would be a monumental feat. Maintaining the gap between the two halves is crucial for the paddles to make the correct amount of contact. The original gasket provides this. Sealant may or may not maintain this spacing, and then there is the issue of sealant oozing inside, gumming up the works. I sure would like to hear about a technique which a do-it-yourselfer could use to reliably perform that task, as I have a box full of wiper motors which need rebuilding. Carl
| | | | | Joined: May 2015 Posts: 11,031 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,031 | I recall disassembling the wiper motor on my Model A and getting it back together and having it work. Of course, the motor was only 37 years old then. Seems like I've been disassembling things since I was a kid. My mom says I once took one of my dad's pocket watches apart, of course without it ever working again. I supposedly took the parts to my dad in my outstretched hands, pleading with him to put it back together.  The vacuum reservoir is a good idea for dependable operation. Mashing the throttle to the floor results in very little vacuum at the intake.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | I have taken them apart and put them back together and they "worked", but lacked the power of a new/professionally repaired one. I am guessing it was due to incorrect space where the paper gasket belongs.
| | | | | Joined: Mar 2017 Posts: 299 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 299 | I removed the vacuum wiper motor and lubed it with atf fluid. Manually worked it and let sit over night. Then I went to the junk yard and found a vacuum reservoir- (cost 5 bucks) from a truck, I took the tubing with the check valve also. Hooked it all up under the dash. And the windshield wipers are finally working. Saved myself 130 bucks.
