5 members (Bill Hanlon, artinva, Hotrod Lincoln, RoadsScholar, 1 invisible), 98 guests, and 1 robot.
Topics128,078
Posts1,055,936
Members48,430
#1300607 02/26/2019 12:53 AM
Just herd about putting moth balls in gas tank to up the octain. Anyone else ever heard of this, and does it work??
Ex Hall Monitor
Ex Hall Monitor
Never heard of it. Sounds like snake oil to me. Do you have a high compression engine that needs higher octane? If so you're far better off just buying it at the local station. If you do it I can just about guarantee that any sweaters you store in your gas tank won't get moth holes in them..... grin
Old wives tale from the 50-60s and no it doesn’t work.
Moderator, Electrical Bay
Martin is spot-on. This was a perpetual rumor when I was in high school so we asked our chemistry teacher. From what I recall the naphthalene moth balls will burn but won't improve gasoline's octane rating. Then there is another type of mothball (sorry, I can not remember what it is made from). Our teacher told us to only put these in your gas tank if you wanted to put an end to your engine. As I recall, when they are mixed with gas and burned, they give off hydrochloric acid. I do clearly remember he thought it would cause the internal parts of your engine to rust very quickly.
~ Jon
Two type of moth balls, containing:
naphthalene - OK, but serves no purpose
or
dichlorobenzene - serves no purpose, BUT it produces HCL
