3 members (66flea, Chris's 46 / 515, TUTS 59), 120 guests, and 2 robots.
Topics128,091
Posts1,056,445
Members48,443
Just got a box of parts back from the body shop (still no truck) but what I thought was my voltage/amp regulator isn't like anything I have seen on line. The truck was converted to 12V and somewhere I have the wiring scribbled down so I know where this part was installed. It has one terminal labelled FLD and nothing on the other. That's right only two terminals. Number on the back is 0399B09. I popped of the lid and there is just a PC board inside. It has 273051141 Rev. H and also 94V-0 and CPC-DPC-E printed on it. The last number googles as a furnace PC? The other numbers don't come up. Anyone know what this is? Its a small rectangle box 2-3/4" x 1-3/4" with mounting tabs. thanks!
Sir Searchalot
Sir Searchalot
If you want it ID'ed, post a pic or two. Some VR's only have two terminals. Let us know if an alternator is used; and if it's external or internally regulated. This could be a legit VR, a gimmick voltage enhancer device or something that fell into the box. If you had the wiring info, it would really help with not guessing.
2 Offline
well, you can ignore 94V-0 CPC-DCP-E
those markings are related to the physical printed circuit board flammability and material laminate type
not related to the form or function of the device
-s
