4 members (TUTS 59, 55shaker, Wrenchman, Oswald), 55 guests, and 1 robot.
Topics128,089
Posts1,056,010
Members48,430
#1299670 02/19/2019 4:46 PM
Where can I find ID information on GMC engines? I have a '48 228 Casting #6107326 with GMC-5 above it. There's also a serial number plate? attached to the block. It's hard to read but appears to be A 228 I or1? 94756. The head has 2136477 and AL underneath. Also on the head is Ferro 2 and F4 8. I assume this is a shift and date code?
6107326 = 1926-1952 GMC 228 block casting CODE
A228 a 228 engine (the A indicates that it came from the factory with non-standard “specs”).
http://www.oldgmctrucks.com/page0311.html
Head and Block codes are shown here.
OldGMCtrucks discussion board
Thanks tclederman!
