| | | Forums66 Topics128,081 Posts1,056,074 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2001 Posts: 182 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 182 | Anyone make their own fan shroud?? Or found a good part/donor shroud? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | I measured up my 58 and went to a wreckin yard that had older stuff and found one close enuff, that I think came out of a 60s Pontiac or Olds - that's the era needed for the old trucks
Bill | | | | | Joined: Feb 2001 Posts: 40 Member | | Member Joined: Feb 2001 Posts: 40 | I got a sheet of aluminum and bent it into a shallow "pan" shape that fit the core area of my radiator. (plus two extra bends for mounting on the sides) I then cut the hole and mounted my electric fan directly to this , I have it on an automatic temp. controled switch and it never gets above 185 degrees . No fan on the waterpump .I polished the aluminum with some "mothers" polish - looks and works great ! | | | | | Joined: Nov 2001 Posts: 182 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 182 | Yea, it's either search the junk yards or make my own...simular to the pan you made (got a picture?) I am running a flex fan on the pump so I want the "pan" deep enough to 'swallow' the fan. They sell an ABS plastic 'pan' that is generic and you cut your own hole...they want up to $75.00 for this piece of plastic! Then you gotta make your own mounting. I refuse. I'm still looking at everything I see that I might be able to make it out of...but I may wind up trying to bend up a piece of sheet metal. Thanks for the input... :rolleyes: | | |
