| | | Forums66 Topics128,162 Posts1,056,937 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2017 Posts: 120 'Bolter | | 'Bolter Joined: Jun 2017 Posts: 120 | I know thi is kind of an odd size, bigger shaft with smaller thread, anyone have this bolt detail. Thanks | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Need some more detail. If you are talking about the bolts that mount the mc to the frame they are 7/16-20. If you are talking about the eccentric plunger pivot bolt it is a dedicated bolt you get from an after market supplier.
Evan
| | | | | Joined: Jun 2017 Posts: 120 'Bolter | | 'Bolter Joined: Jun 2017 Posts: 120 | these are the bolts that run through the M/C to bolt to the frame bracket | | |
