1 members (Hotrod Lincoln), 61 guests, and 2 robots.
Topics128,049
Posts1,055,740
#129878 04/12/2002 11:31 PM
Ok, I have in transit to me an Edmunds 2x2 intake and a set of Holley 2100/94 carbs (Like strombergs). I am ordering a set of adjustable main jets but I am also looking for suggestions as to what power valve closing vacuum I should use. I think original was 6.5 or 7 in single carb apps but Holley power valves are available down to 3. Any suggestions where to start? I am thinking 4.5 because that is half of seven and I am using 2 carbs. This is for a 235 with solid lifters and stock truck cam (I think). I am going to add a hotter cam later. The carbs are operated with each carb feeding 3 cylinders. The intake is water heated.
Paint & Body Shop moderator
#129879 04/26/2002 4:55 PM
3.5 +3.5 =7
grin
I do not have any answers for which ones to use in your carbs,,,,yet!
#129880 04/27/2002 5:07 PM
start out by getting a uni sinc tool the jetting has come from sombody is current.
the book by weber carbs "theory of carburation" is a realy good book and kay sisel and guys like him have some good books on carb tunning grin
i thinkzz traveling along at terminal velocity will soon wear a body out.
i will not die in shame if i never finish my dreams because my family iz my reality
can't wait until we can bed de ponys down, lite de fire, put on a big ol pot of coffee, and talk about how strong and brave our teams are.
bullfoot thinkszzzzzzzzzzz
