0 members (),
254
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | We have switched to the LS series engines for almost all our swaps anymore but since my eyes have kept me out of the shop I can turn the laptop up to 150% and read up on engines. For ones wanting to simplify the swap by going to a carb it will gain you about 100hp but lose you around 30% in fuel mileage. Figures seem to be 435hp/25mpg for the Camaro-Corvette computerized and injected LS vs 550hp/17mpg for a carbed one. Leaves a decision to make.
Evan
| | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | How is timing advance managed on the carb-equipped engine? Is there a computer still involved, just not for fuel metering? Jerry
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Jerry, I'm new to this and still a dummy but it seems all the ones making dyno runs on youtube are using the MSD LS6 ignition controller. A search of "timing control on carbed LS3" will give details that you will grasp quicker than me. The 4 cam Mercury Marauder (Ford) engine I have in my 34 Chevy coupe has an MSD control unit and it has been OK but not a versatile as I'd like. Before I lay much blame on the MSD unit I could probably look in a mirror and find the real culprit who chose to go with 4 Webers. When I can start doing stuff in the shop again the Webers will be gone and I'm going to try the Factory Five electronic stack injectors they offer on the Coyote engine. Surely they must be better than the Webers. I have dialed in a Weber on the dyno but it took more hours than my legs can take anymore.
Evan
| | | | | Joined: Jan 2019 Posts: 77 'Bolter | | 'Bolter Joined: Jan 2019 Posts: 77 | This is for ==== coilover
I used to work in Plano , Tx .... way back when. I would help my older brother in the "Paint & Body Shop" @ Roy Lewis Automotive , in "downtown Plano" ------------------- back, when 'it was plane-o". also, I worked at the "Gemini Drive-In" , back down Hwy 75 ( Central & Forest Lane), back in my youth. The same Family owned both 'Drive-in's = Gemini & Plano Drive-in. The last time we were back in your area ....... It's Th' Big City, ...... but that's been awhile by now. (When my Mom passed -- she lived around Copeville, (Lake Lavon at that time).
Brings back some good - times ........................... and, just saying Hi.
(Those guys over on the "SNS site" (Nova site) , sure are going with the LS series engines , in their cars. BUT, I kinda like my 'stock 250 - banger & T 5 tranny, with my Holley '390.
later,
Jim | | | | | Joined: Aug 2016 Posts: 146 Shop Shark | | Shop Shark Joined: Aug 2016 Posts: 146 | "Carbed LS" is an oxymoron. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | I see your point; when I put a SCOT supercharger on my old 40 Ford the engine was no longer a Flathead and when I put Jackson injectors on my 327 ChevyII it was no longer a small block Chevy.
Evan
| | | | | Joined: Feb 2004 Posts: 29,792 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | Unless you also installed some Ardun heads, they were still "flat", weren't they? My 47 Mercury had a 4" stroke 51 Merc crankshaft, an 80 overbore, and Offenhauser finned aluminum heads- - - - -and it was still a "flathead!" Jerry
