4 members (Danielbolt, Rich'sToys, 54farmtruck, 1 invisible), 96 guests, and 0 robots.
Topics128,157
Posts1,056,875
Members48,456
I have installed a new reproduction turn signal switch unit like the original accessory. I am running separate rear turn signal‘s so I’m not utilizing the white wire that runs to the brake light.
It is all connected, the entire left side functions normally, the right side does nothing, any thoughts on what the problem might be? Flasher lights looks normally in the speedo for the left side as well.
Anyone had any issues with the switch being defective inside the signal unit itself?
Check your grounds. It's pretty simple to check the switch for continuity- - - -just takes a voltmeter, or even a test light at the steering column wire harness.
