| | | Forums66 Topics128,157 Posts1,056,874 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2017 Posts: 120 'Bolter | | 'Bolter Joined: Jun 2017 Posts: 120 | I have installed a new reproduction turn signal switch unit like the original accessory. I am running separate rear turn signal‘s so I’m not utilizing the white wire that runs to the brake light.
It is all connected, the entire left side functions normally, the right side does nothing, any thoughts on what the problem might be? Flasher lights looks normally in the speedo for the left side as well.
Anyone had any issues with the switch being defective inside the signal unit itself?
| | | | | Joined: Feb 2004 Posts: 29,851 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,851 | Check your grounds. It's pretty simple to check the switch for continuity- - - -just takes a voltmeter, or even a test light at the steering column wire harness. Jerry
