| | | Forums66 Topics128,186 Posts1,057,317 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2018 Posts: 28 1935 1.5 ton military | | 1935 1.5 ton military Joined: Aug 2018 Posts: 28 | So. I took Qubie down to the local tire guys to see if they could balance the wheels. A couple of the wheels are so warped that the guys were cracking up just watching them wobble back and forth on the machine...
The real problem occurred at the right rear. One of the wheel studs is totally stripped, you can rotate it with your fingers. So, I can't remove the rear wheels on that side. If I ever get a flat, I'm screwed.
First question; is there any chance that it's only the knurling on the stud that's damaged, and that the hub may still be Ok?
Next, I have a spare set of FRONT hubs. Are those studs the same as the rears? Or alternately, is there any chance of finding a good wheel stud for the rear of a 1935 1.5 ton?
And finally, how can I get that bad stud out? Can I break it off? Can it be drilled out, or is the steel too hard for anything but diamond drills? I was thinking that maybe if I could attach a slide hammer, I could reseat the stud enough to get the lug off...
Opinions anyone?
'35 1.5 ton military
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Split the nut to remove it. Probably by drilling a 1/4" or so hole in the nut parallel with the stud on one side or two opposite so it's weak enough to split with a cold chisel. Or you may have a nut splitter shaped such and strong enough to get in there and do the job. Very unlikely that the stud is reusable. Possible no damage was done to the hub, you won't know until you get it apart. Replacement stud is likely available from NAPA or your favorite auto parts store. First try looking it up by application, then by dimensions if no luck by application. Here's the original parts book page about hub studs and dimensions. http://chevy.oldcarmanualproject.com/parts/1929_54/370.htmThe parts catalog will be your friend, introduce yourself. http://chevy.oldcarmanualproject.com/parts/1929_54/index.htmMore good manuals and literature found here http://chevy.oldcarmanualproject.com/ | | | | | Joined: Aug 2018 Posts: 28 1935 1.5 ton military | | 1935 1.5 ton military Joined: Aug 2018 Posts: 28 | Thanks Grigg, I'll try the drill and split, and report back. I tried taking off the other nine... Turns out that at least 4 lugs have threads damaged enough to prevent them from keeping the wheel tight. I've been driving around with only half the lug nuts doing their job. It's a good thing I haven't been working the truck!
| | | | | Joined: Feb 2016 Posts: 1,996 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,996 | Thurman, can you take all of the nuts off other than the problem stud then use the wedging force of the wheel to put tension on the loose stud - you might get lucky enough that the nut can be backed off.
