0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2002 Posts: 68 Member | | Member Joined: Jul 2002 Posts: 68 | Does anyone here have a suggestion on a steering box swap for a '54 3100? I've tried the search, but nothing shows up.
'54 3100-235-T5 trans-12 bolt 3:31 '68 Impala 307/350 '78 Sportster/Original owner
| | | | | Joined: Jan 2002 Posts: 398 Member | | Member Joined: Jan 2002 Posts: 398 | Do you want power steering, wingnut? If so, check out www.classictruckshop.com They have a reasonably good article concerning just this swap. They used a commercially available kit to install later model ('73-'89) GM full size 1/2 ton steering box on their AD 1/2 ton. Just check the "tech articles" section on the left side of the screen. I believe this kit is available from most of the major parts vendors, prices range from $95-$125 U.S. Hopefully you will find some more of the information there that you are looking for. Best of luck. Regards, Wannabe
"Don't expect anything and you'll never be disappointed"
| | | | | Joined: Jul 2002 Posts: 68 Member | | Member Joined: Jul 2002 Posts: 68 | Thanks Wannabe, I'll check it out. I haven't made up my mind if I'm going with P/S or staying with manual.
wingnut
| | | | | Joined: Jan 2002 Posts: 398 Member | | Member Joined: Jan 2002 Posts: 398 | Wingnut, I just had another thought (question). Are you wanting to change your steering out because of an engine swap? If you've put a V-8 in there, you can just space the stock box about 1 1/2" out from the frame using seamless steel tubing, longer Grade 8 bolts and a piece of steel plate. then you heat the pitman arm and bend it in slightly to bring it back to its stock distance from the frame. Just thought this might be another option for you. Regards, Wannabe
