4 members (MikeE, lc_btv, Oldcaliforniakid, Rexville48), 104 guests, and 3 robots.
Topics128,050
Posts1,055,673
#1295146 01/17/2019 4:10 AM
I know remote diagnosis is difficult at best. Nevertheless, your help would be appreciated. There is a vibration in the shift lever of my SM420, which is in a '59 3800 with 261. What is the most likely culprit: u-joints, transmission bearings, or something else?
Oldbolter
1959 Apache 3800 dually flat bed/dump with 261
1956 3800 dually flat bed/dump with 235
1957 3600 flat bed, 350 engine, 700R4, PS, disc brakes, 14 bolt rear with 4.11 gears
oldbolter #1295155 01/17/2019 10:55 AM
Is there a spring where the shift arm/lever enters the top of the transmission?
The cross sections of the spring ca...illustration of the SM420 transmission.
Yes, the spring is there.
Oldbolter
When does it vibrate? which gears, idling in neutral, idling in gear with clutch in?
Check the first/reverse gear for rock on the main shaft (requires the mainshaft removal and disassembly), it should be no more than .015".
Also, check the shifting yokes for wear, the clearance between the shifting yoke/fork and sliders should be no more of a gap of .020, prefer .010.
I recently rebuilt a sm420 for a guy and it had a hell of a vibration in the shifter and on inspection I found both situations, the first gear was worn allowing a rock on the main spline of .040 and clearance on the 1st and 2nd shifter yoke on the first/reverse gear to be .035.
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
sstock #1295362 01/19/2019 1:14 AM
Thanks for the help. It looks as though I need to dig deeper into the trans.
Oldbolter
