5 members (Gdads51, Rich'sToys, jasrking, TooMany2count, FishinToms53), 119 guests, and 1 robot.
Topics128,126
Posts1,056,354
Members48,441
#1290349 12/08/2018 8:18 PM
It was the typical tired old bed, rotten wood with a rusty metal plate welded on top. So I my nephew and I cut the metal plate out and carefully measured all the old wood, spacing and bolt holes, then replaced with new red oak and stainless strips and bolts. I did lots of panel beating on the sides and had to replace the front panel and tailgate with new GM repros. The color is Seacrest Green.
Sweet job. You should be proud of yourself. yahoo
Nice job ! In the process of trying to figure out what parts needed for a '52 3600 bed on truck that was in pieces when I got it. Any idea why on the parts catalogs why they do not seem to list a front sill for
3600 ?
Fox Offline
I know my one ton does not have a front sill. I assume the 3/4 tons are the same. The front bed panel has a lipped slot the bed wood slides into. The 1/2tons have a front sill that bolts to the front panel. The 1 tons (possibly 3/4s) have this incorporated right into the panel. The rest of the sills are all the same on my one ton until you get to the rear/tailgate sill/panel.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
