| | | Forums66 Topics128,118 Posts1,056,304 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 67 | It looks I might be picking up a 1957 GMC 270 or it might be a 370 ( I can't beat the price). I don't know to much about this vintage or their model numbers. 1. What was the 270 or 370 series rated for? 2. What other vintage and series interchange parts wise?
1937 Chevy (converted to 4x4) 1942 Chevy G506 1.5 ton 4x4 1958 Mack B model (on Chevy 1 ton 4x4 frame) 1969 Dodge Charger 1987 K30 Crewcab
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | So is it a 270 or 370 engine? GMC used both or are you talking about the series of truck. If so it would be a 370 series would be a 2 1/2 ton. It uses the same cab as pickups unless it is a low cab forward model. These can be identified by a cutout in the door for the fender. Engines are interchangeable from 100 to 400 series without modifications. Front sheet metal.. hood, grille, fenders of all 300 series are interchangeable. I think a 400 series would be the same. A 450 series uses a totally different front end. If the front sheet metal is good, about the only expensive part to fix is the brakes and of course it takes 6 instead of 4 tires and they are more expensive than lighter tires. | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | So is it a 270 or 370 engine? GMC used both or are you talking about the series of truck. If so it would be a 370 series would be a 2 1/2 ton. It uses the same cab as pickups unless it is a low cab forward model. These can be identified by a cutout in the door for the fender. Engines are interchangeable from 100 to 400 series without modifications. Front sheet metal.. hood, grille, fenders of all 300 series are interchangeable. I think a 400 series would be the same. A 450 series uses a totally different front end. If the front sheet metal is good, about the only expensive part to fix is the brakes and of course it takes 6 instead of 4 tires and they are more expensive than lighter tires. Cabs are the same from late 55 to 59. Fenders are the same from late 55 to 57. 58 came out with dual headlights.
| | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | ken, my bet is on the 370 series with a 270 | | | | | Joined: Apr 2009 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 67 | Thanks for the the info. The truck series is a 370. It has no motor or trans and not even sure what it came with. I was actually thinking frame swap. But for a couple of hundred dollars, I'll buy it now and figure out what to do with it later. Besides, my 10 year old daughter said, "Dad, it looks like "Mater" from the movie Cars, you should buy it." So I said OK - (sounds like a good enough reason to me). Sometimes I think I keep buying these trucks to see if the wife's little head could possibly shake side to side any further.
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Mike, I'm quite sure its a 370 series, but one never knows. Someone may have a 370 motor and want to get rid of it. Originally I thought I was going to take the wrecker body of the rig I bought from Harold, but I have decided to keep it a wrecker. I would love to find another 370 motor and build a truck tractor like I drove 45 years ago.
| | | | | Joined: Mar 2010 Posts: 1 New Guy | | New Guy Joined: Mar 2010 Posts: 1 | I have an engine and transmission for the 1957 GMC 370. The engine runs and the transmission works. Let me know if you would like more information. 651-460-6867 I am in south eastern MN | | | | | Joined: Apr 2009 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 67 | I finally got the truck. It is a GMC 370. The fellow said it came with a Pontiac V-8 originally. The tag inside the door said 200hp. I pretty much bought it sight unseen. So here it is - Its all their and the front clip isn't in to bad of shape, but the cab and doors are pretty rough. The frame is in excellent shape and it steers and rolls easy.
So I'm not sure if I'm going to put this one back together. I've put worse back together, but I don't know when I'll ever get around to it. So if anyone out thier wants it or needs parts - let me know, i'll let it go cheap. I'd rather see someone do something with it then sit in my back 40. When I get a chance, I'll try to get some pictures posted. You can give me a call if your interested (815)347-2944 - Jeff
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | The cab is the same as a pickup. The front clip is different. The engine could be a 336 or 347 which do well in pickups. Restoring a larger truck is more expensive than a pickup, and unless you particularly like larger trucks, you may not know what to do with it if you complete it. I have several larger GMC's, but that is because I have been the trucking business for over 45 years. They are not for cruising around town and won't fit in a normal garage. | | | | | Joined: Nov 2018 Posts: 4 New Guy | | New Guy Joined: Nov 2018 Posts: 4 | I am interested in your front grill and eyebrows if you got them available still. I have a model 3 70s, School Bus, mine also had no motor with it, originally came with the Pontiac 347 for that year, looking for one of those also. | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | This is a nine year old thread. Kind of a long shot. Plus soliciting parts in the garage Forums is prohibited. Place a Wanted ad in the Swap Meet Forum.
