4 members (MNSmith, Charles in CA, Otto Skorzeny, Hotrod Lincoln), 59 guests, and 2 robots.
Topics128,052
Posts1,055,718
#1294872 01/14/2019 6:35 PM
On my 63 Chevy step side, going to replace the boards in the bed... Started to loosen the nuts on the bottom side, kept spinning.... Finally got a carriage bolt out and
the metal slats between boards have ROUND holes in them, nothing to hold sq carriage bolt from spinning..... Am I missing something, the old
Round hole and Square peg doesn't seem to work here.... Gotta be a trick to this !!!
Tobztub 63 Step #1295267 01/18/2019 10:53 AM
Tobz,
Not sure where the replies disappeared to. I reviewed 5-6 replies to this thread previously. Did you get the info you needed or do we need to dig up the history?
Dont want this question to hang if you still are looking for the answers.
Bottom line: the square holes in the bed strips are rounded out. Need to cut bolts, cut heads or put vice grips on heads while someone turns nuts off or turns them to break. If you are not saving the bed strips and/or wood you may be able to get a sawz all under the heads and cut. And as you know there are a bunch of bolts.
Hambone
~ HB
1962 Chevrolet C10
1962 Suburban
Tobztub 63 Step #1295346 01/18/2019 11:24 PM
First, I suggest heating each nut from the bottom and then let them all cool. If you don't have an gas welder setup, a propane torch will do. This will help loosen the bond between the nut and the bolt.
Then, take a 4" angle grinder with a thin cutoff wheel and slice a slot into the top of each carriage bolt. Then you can prevent the bolt from rotating with a BIG screwdriver and have someone underneath wrench the nuts off.
Cheers, Dean
Dean 'Rustoholic' Meltz
Lurch: 1927 1-Ton Chevy Cattle Truck
Old and ugly is beautiful! -- The Saga
Lurch's Gallery
Justin: 1928 Chevrolet AB Canopy Express
