2 members (artinva, Chip O), 112 guests, and 2 robots.
Topics128,072
Posts1,055,904
Members48,429
#1294561 01/12/2019 5:49 PM
I've been noticing on last few trips that as I'm coming to a stop the brakes are grabbing right at the last moment. Everything seems great slowing down, but just before I finally stop it's as if i applied more force. They also seem to take a bit of movement starting again to release. Yet all seems good under way.
1952 3 ton with hydrovac. New master and hydrovac, good friction surfaces.
Thanks!
1952 Chevrolet 1700 Bickle Seagrave
"Old Smokey'"
Following the build in the DITY Gallery
52vff #1294596 01/12/2019 8:51 PM
3B Offline
Hy 52vff, check your brake adjustment, remove the drums and check for contamination by bearing grease, differential oil and brake fluid. Also check all suspension bolts for tightness, hope that helps.
52vff #1294635 01/13/2019 12:44 AM
7
7 Offline
Sounds like one or more is in need of adjustment - too loose. But do as 3B suggests and check for oil or grease on the shoes.
52vff #1294742 01/13/2019 5:50 PM
Riding in the Passing Lane
After checking what 3B mentioned make sure your brake cables are free & not adjusted too tight. Grind or sand a bevel on the edge of the linings. Often the sharp edge on the linings grabs the drum. I had this happen just recently on my daily driver GMC Sonoma. Sanding a bevel on the edge of the linings on the rear wheel that was grabbing cured it.
1972 Chevy c10 Cheyenne Super
52vff #1294747 01/13/2019 6:40 PM
Check to be sure there's a little free play between the brake pedal pushrod and the main master cylinder piston. If it's not able to depressurize after a stop, there will be just enough residual pressure to keep the hydrovac applied. We fixed a brake-locking problem on John's pumper fire truck that way at Homecoming one year.
