| | | Forums66 Topics128,184 Posts1,057,270 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2019 Posts: 3 New Guy | | New Guy Joined: Jan 2019 Posts: 3 | I have a 1949 gmc 9' bed with the Muncie 4 speed and a 248 (I think. could be a 228) it runs and drives ok but it's really low on power. I've rebuilt the carburetor, replaced the points, condenser, ignition coil and spark plug wires, replaced the intake and exhaust manifold gaskets, removed the exhaust riser butterfly, adjusted the timing, valve adjustment and probably a few other things I can't remember right now. It has 98 psi compression across the board +/- 4 psi and runs good oil pressure. Is there anything else I should try to get more power out of it? Because recently a military 302 showed up near me on CraigsList and I was considering a swap. Are the engine mounting points bellhousing etc for the 248 the same as a military 302? Thank you for your time!
I have a lot of interests in old machinery and electronics. My parents bought me a 1949 GMC 1 ton 9 foot bed project truck for my 11 birthday and I've loved it ever since.
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | The ser. no. Starts with the displacement , I. e., 228xxxx. Seems like military front mounts are different, however, center bottom, front mount could be used, or make your own front side mounts. Your bellhousing is probably too small for a, 11" clutch, might need to get a later bellhousing, or get an adapter plate to use a modern bellhousing. Your existing flywheel is probably 4 bolt, 302's have 6 bolt flywheels, so use the 302 flywheel. Chevy flywheels can also be redrilled to the 302 pattern. Military 302 oil pans are extra deep, OK to use unless too high. Only 270 and 302 oil pans work on 302's, longer stroke requires sides of pan to be wider.
Makes your truck more useful. Easy swap to do if not in a hurry.
Ed
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Welcome,
Do you have 5.13 axle gears or something faster?
A 228 is plenty enough power for slow gears, and your engine sounds like it's in good tune, or should be given your work on it unless something is off. I have 4.10 gears in mine and a somewhat worn 228, it drives nicely, enough power still. (though more would be fun)
A 302 and faster gears would be great, but first find out why you're not satisfied with it as is? What are you comparing the truck to, why do you think it is "low on power"? | | | | | Joined: Jan 2019 Posts: 3 New Guy | | New Guy Joined: Jan 2019 Posts: 3 | I believe mine is a 5.12 or 5.13 rear but I get passed by semi trucks when pulling away from a light. I don't know how quick these trucks are meant to be as i've never driven another one. But it seems like it should be faster. What do you guys think?
| | | | | Joined: Jan 2019 Posts: 3 New Guy | | New Guy Joined: Jan 2019 Posts: 3 | I appreciate the response! Yea it's a complete engine with all accessories. Would it be ok to use the front center mount hold the 302 engine up? I have a craigslist add link are you allowed to post those here? I'll check my engine's serial # here soon to check for sure what size mine is.
| | | | | Joined: Aug 2011 Posts: 229 'Bolter | | 'Bolter Joined: Aug 2011 Posts: 229 | I have a heavy 51 with a 228 and converted rear end from 5:14 to 4:10s. The engine is strong with good torque but limited HP. It will do 50 MPH with a good run on flat ground, but takes a while to get there. Hills are a different story! I think the stock 228 engine is maxed out with our heavy trucks. | | | | | Joined: May 2006 Posts: 934 'Bolter | | 'Bolter Joined: May 2006 Posts: 934 | Check out Inliners International, OldGMCtrucks, and research this site for the list of tasks needed to convert a military 302 to civilian application. Currently doing the same and wrapping up this project just today. I found a Craigslist a 24V 302 that was surplused and completely rebuilt but never run. I still disassembled it to do some block work for full pressure oil conversion, dip stick hole drilling, cutting the opening for the mechanical fuel pump and grinding down a large boss that was part of the block casting. Added the standard front mount timing plate and cover, did not use the 302 flywheel because it was for a completely different automatic military hydro transmission, but acquired a trashed 270 for swap parts such as oil line for rocker arm, oil pan, fan, bellhousing, flywheel, starter, distributor, oil pump and sump, and other miscellaneous parts. A 270 oil pan is the same width but deeper and heavier than the 228 oil pans I have - seemed like a better choice.
You can do the same with your 248 and switch over everything that attaches to the block, head, or crank. Your 248 timing plate and cover, oil pan with pump, distributor, water pump, thermostat housing, all will be a direct replacement.
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | 248, etc., pans will not fit 270's, etc., because of the longer throw.
Ed
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | 248, etc., pans will not fit 270's, etc., because of the longer trove. Ed Excuse my ignorance, but, what is a "trove"? | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Probably misspelling of “throw” | | | | | Joined: Jun 2001 Posts: 793 Bondo Artiste | | Bondo Artiste Joined: Jun 2001 Posts: 793 | A military 302 can be converted to fit in your truck, but its not a easy conversion in my opinion. A civilian 302 is almost a direct sway depending on what year range you go with. A 270 or 302 would be a great upgrade to your truck, along with the 4:10 rear. The 4:10 rear change will be a quicker upgrade than changing engines. I would start there and then see how you like the truck and then if you need some more power then start looking for a good 270 or 302 to drop in.
On a another note....
"248, etc., pans will not fit 270's, etc., because of the longer trove."
I used my 228 oil pan on a 270 swap back in 2008, on my previous 52 GMC half ton without any issues. My 45 GMC has a civilian 302 in it right now with a 228 oil pan, again no issues. Not sure where your info is coming from but I've made it work without any alterations.
Yes, there are different oil pans between the 228, 248, 270, and 302 engines. but from I understand the differences have to do with oil capacity, not a "fitment" issue between the blocks.
~ Phillip 1949 GMC Suburban - 10 year project 1952 Pontiac Chieftain Convertible straight 8 hydramatic 1945 GMC half ton truck - Driver- Sold 9-15-25 1946 Chevy COE - SOLD 1-5-26 BUH BYE CHEVY! 1959 GMC Half ton long bed NAPCO | | | | | Joined: May 2006 Posts: 934 'Bolter | | 'Bolter Joined: May 2006 Posts: 934 | That was my understanding regarding the oil pans as long as the oil pump was compatible with the depth of the pan. I’m certainly no expert on this subject but I did a lengthy search with others before I converted the military 302 to civilian use.
| | | | | Joined: Mar 2005 Posts: 171 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 171 | 248, etc., pans will not fit 270's, etc., because of the longer throw.
Ed My 302 has a 228 pan on it it offers no interference with crank/rods whatsoever. | | | | | Joined: Mar 2005 Posts: 171 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 171 | 248, etc., pans will not fit 270's, etc., because of the longer throw.
Ed I’ve got a 228 pickup oil pan on my 302. Fits just fine just needs the corresponding pickup tube on the oil pump. No interference with crank/rods whatsoever. | | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | "removed the exhaust riser butterfly"
This may be causing you some performance issues.
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
