8 members (walter74, TexasJim50, MarkT, Gdads51, Hotrod Lincoln, Tinker5, MNSmith, 39Master85), 132 guests, and 3 robots.
Topics128,164
Posts1,056,978
Members48,458
Bought a 54 3100 . I was Painted real good, but needs a lot of mechanical work. Have rebuilt the suspension and the brakes. am in the process of rewiring. While the wiring harness was out painted the engine and under hood. need to repaint the interior of cab. The glass in both wing(vent) windows needs to be replaced. This is how i found this site. my other toys are from brand F. (three model A's and a 65 Mustang conv.) am enjoying working on the 54 but have been stumped on R&R the vent windows. Any help would be appreciated.
Thanks in advance.
Do you have a 1954 Chevrolet Truck Shop Manual?
(door ventilator assembly)
If you do, what instructions/etc has you stumped?
i do hve the Shop Manual. I am looking for information on r&r the vent window. They need to be replaced on both sides. i have the screws removed around the frame but not sure how it is installed in the door. i did not find any information in the shop manual about the doors/windows. Thanks for any help you can give me.
Frank
We have a sub-Forum in the Paint and Body Forum called Doors. Your question should be posted there. You will get lots of help there.
Thanks I will try that.
Red dot, center of chest ...
Be sure to look through the Techtips section. There's a lot of helpful information there.
Paul Schmehl CI 6
geek@stovebolt.com
Stovebolt Staff: Geek
