| | | Forums66 Topics128,208 Posts1,057,446 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | Thought I'd pass this on. This last weekend I installed a front end sway bar on the 3100/54. It bolted right on and the difference in the the handling is GREAT and much safer in the corners! This was the best add on feature I have ever installed bar none. The kit was purchased from CCP and bolted right up in two hours.....very sweet! Try it you'll like it! Steve  | | | | | Joined: Mar 2005 Posts: 25 Apprentice | | Apprentice Joined: Mar 2005 Posts: 25 | Do you know if the sway bar you bought from CCP will fit a 1941-46 Chevrolet Pickup?
Ted | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Thanks Who me. I have one ordered from CCP for my 58. They have been a little slow getting it here but I called & they say it should arive weds. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Hey Wrench, you'll like that bar on the '58. I've got them on both ends of the '55. I'm not gonna say it corners like a sports car, but it does handle the corners very well for an old solid axle leaf sprung truck. Add a set of decent gas shocks (I'm running Gabriel Red Riders) and you'll be set.
Bill Burmeister | | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | HI..Ted the sway bars are year specific but I think there is one for the years you mentioned, check their web site.
Bill that's what I did new shocks with the new sway bar its the only way to fly.
Wrench...they showed up real quick and I ordered from their web site. The instructions that come with the sway bar are almost unusable they are too small and the parts are not numbered. I downloaded the pictures and the install article by Leon Corley courtesy of Chevytrucks.org ..THANKS, Steve | | | | | Joined: Sep 2015 Posts: 157 'Bolter | | 'Bolter Joined: Sep 2015 Posts: 157 | LONBOX55,
Check your PM, I have some front sway bar questions for you. Thanks
Dan
35 CC Case 38 Chevy Pickup 51 3100 AD 58 3100 Apache Fleetside
| | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | DB Cooper Thread is 12 years old and longbox55 hasnt been on since 2017
1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Nov 2000 Posts: 1,974 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,974 | Sometimes life gets busy and interest change. Twice I stayed off here for 2-3 years because of lack of interest and no truck to gab about.
Professional Novice
