| | | Forums66 Topics128,094 Posts1,056,465 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2018 Posts: 18 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 18 | Does anyone know what material the valve guides are made from? I read that most engines have cast iron guides for the porosity and oil lubrication.
55 GMC 3100 2nd Series 71 GMC 1500 Super Custom 1956 Thriftmaster 1954 Blue Flame 1962 Thriftmaster
| | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | They can be bronze, brass, CI. What color are the old ones?
Ed
| | | | | Joined: Dec 2018 Posts: 18 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 18 | The old ones appear to be steel or cast iron, not bronze in color.
| | | | | Joined: Jan 2013 Posts: 10 New Guy | | New Guy Joined: Jan 2013 Posts: 10 | They are cast iron, bronze are nice but costly. | | | | | Joined: Feb 2004 Posts: 29,829 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,829 | A competent machinist can install any kind of guides you want in a stovebolt head. Bronze guides are nice, but not really necessary. The original equipment guides are cast iron, mostly because they were, and are cheap to manufacture. Jerry
| | | | | Joined: Dec 2017 Posts: 1,652 'Bolter | | 'Bolter Joined: Dec 2017 Posts: 1,652 | I number of years ago I had I head I was redoing that, for whatever reason, we were having a very difficult time getting the original guides out for replacement with new. Ended up using just a little too much pressure and broke the casting, instantly turning a perfectly good head into a boat anchor. From that point on I have opted to have bronze liners installed into the original guides and then finish the guides to a proper clearance with respect to the valve stems. It’s slightly more expensive, but I think yelds a better end result with respect to oil control on the stems.
Mike
| | | | | Joined: Feb 2004 Posts: 29,829 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,829 | Removing guides without boring them out to a thinwall shell is risky business. Once the guide wall is around 1/16" thick, a simple driver mandrel in an air hammer pushes them out easily. I learned that trick while rebuilding air cooled Volkswagen cylinder heads, but it works well on any engine with removable valve guides. Jerry
| | | | | Joined: Dec 2018 Posts: 18 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 18 | Well you both gave me more good information to consider; unfortunately I already pressed the old ones out- but with no issues. It took 8-12 tons on the press gauge to get them out. So far so good. I am making the new ones so I can determine the press fit and clearance etc..
| | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | I hate to be the cold water, but with that much force I would put the head on a lathe bed, run a dial indicator along the gasket surface to check for flat. If you haven't pressure tested it consider it an investment - better to find out now then when it's assembled. | | | | | Joined: Feb 2004 Posts: 29,829 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,829 | Unless you supported the area around each guide as you did the pressing, you've probably got a boat anchor. Ditto on the pressure test, and at least get the head gasket surface milled a little to be sure it's flat. Situations with long pieces of cast iron and ham-handed methods seldom end well. Straightening a bent cast iron crankshaft is done with a big lead hammer- - - - -not a press. Why are you making guides? They're available ready-made by the hundreds. Jerry
