2 members (2-Ton, JW51),
67
Mod | | | Forums66 Topics128,055 Posts1,055,783 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2013 Posts: 56 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 56 | My question concerns brake backing plate, since the bleeder screws are so close to the spring stack, could the plate be turned one bolt hole to mount new brake cylinders ? It is the only way to bleed the brakes on my ton truck that I know of, thanks Pat?
1966 Chevy C 30 1 ton truck
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I don't know what you mean by "turning one bolt hole" but you can take out the bolts that hold the backing plate on & service the wheel cylinder & bleed it. If you don't let the master cyl. run low all the air will be right at the cyl. You can put a C clamp on the cyl. to keep it from coming apart while you bleed it. George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Bleeder screw needs to be at the top to remove all the air, which it is in original configuration. Turning backing plate 90* likely traps air. | | | | | Joined: Feb 2013 Posts: 56 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 56 | Thank you for the advice. Pat
