5 members (Phak1, Paul_WNC, Otto Skorzeny, WICruiser, 68ironhead), 181 guests, and 9 robots.
Topics128,078
Posts1,056,036
Members48,433
I keep hearing about the cardboard headliners and door panels warping over time due to moisture. I bought some spray silicone and gave both sides of my new cardboard three coats. Now my cardboard beads water. Not sure how long it will last on there but from my musical Instrument repair experience....one silicone gets on something it's hard to get off. Maybe this info will help someone.
1950 SUBURBAN / SCHOOL BUS A.K.A "THE SCHOOL RUST"
That silicone will most likely make it difficult for paint to adhere in the future?
And it might contaminate areas it touches?
Yeah, I thought of that. I figure if it's going to contaminate, it will only be under the panels where I cant see anyway. I hate silicone for that very reason.
Moderator, Electrical Bay
We always use Varathane brand of polyurethane on fiberboard and especially mdf. It doesn't prevent paint later and makes the stuff last much better. The first coat soaks in but the second one doesn't. Usually two coats are enough but if you're in a really humid area, 3 is better. Let all coats dry for at least 72 hours and preferably longer. Once that stuff soaks in the top surface skins over and makes the drying time a lot longer. Just be certain to get the edges very well coated. You can't really seal those too well. Otherwise humidity will get in and those panels will still warp even though the front and back is sealed. If you've ever seen a countertop made of particleboard which wasn't sealed you know what I'm talking about.
~ Jon
Moderated by  ndkid275, Phak1
