2 members (68ironhead, stlcardinalsguy), 187 guests, and 14 robots.
Topics128,078
Posts1,056,036
Members48,433
#129258 12/21/2004 4:46 AM
My son's '46 Chevy 1/2-ton will soon start it's road to resurrection. I'm looking for a good IFS swap for the '46 that's proven and won't bankrupt the project. Ideas?
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass.
Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
#129259 12/21/2004 9:47 PM
I know a guy who has swapped an entire S-10 frame under a '39. I believe the '39 and '46 are similar enough underneath that it shouldn't be too difficult. He is about 600 miles from me, so I can't just drop by and take pictures...
I've seen a couple of Art Deco trucks with Corvair IFS underneath. I'm told its a pretty simple project, and likely not very expensive. If I remember right the Corvair Greenbriar van IFS is supposed to be the best one for this. They were not available with disk brakes, though I know some conversions were available for the cars.
Another idea might be to grab a Toyota pickup frame from the years when they used 6-lug wheels. I haven't looked at one with out a body, but from underneath they look easy to work with. You'd then have modern suspension and the ability to run stock looking wheels.
I toyed with putting a 4x4 Toyota under one of my trucks. The wheelbase was short, but otherwise the measurements all seemed doable for a '54 Chevy.
Obviously I'd rather think up answers for your truck than work this afternoon. I'd better focus on getting something done!
HTH!
#129260 12/28/2004 12:14 AM
Junior Member
Junior Member
Quote
Hi, I have a 39chevy that I put a sub frame under it out of a 78 nova ,wasn't a hard job at all some welding and some bolting up ,made one heck of a differance in ride and handling,and a plus is disc brakesan power steering, have fun Slim ps older camaro's are the same ,
Slim "Chevys are Forever"
