| | | Forums66 Topics128,014 Posts1,055,330 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2017 Posts: 5 New Guy | | New Guy Joined: Feb 2017 Posts: 5 | 56 450, V8, 336 pontiac, Having troubles locating a pressure plate.
The kits, like the Rhino Pac 04-502 have the correct disk, but the bolt pattern doesn't match. 12", 10 spline disc
Any suggestions are appreciated! | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy allMETALS, all the research I have been able to do indicates the 04-502 should work. Could you tell us if the bolt spacing is wrong on the flywheel, or if the number of bolts to retain the pressure plate is incorrect? | | | | | Joined: Dec 2017 Posts: 1,652 'Bolter | | 'Bolter Joined: Dec 2017 Posts: 1,652 | Do you have an old pressure plate? If you do, send it to HR Clutches in Bensalem Pennsylvania. They built all the clutches and pressure plates for Hurst when Hurst moved Scheiffer to Pennsylvania. They have been in business for years. I have used their clutches since I was a teenager. In fact, they rebuilt one for me in 2015 that I originally purchased from them in 1984. They also rebuilt my decades old Scheiffer pressure plate. These old plates are made from good American steel and can be rebuilt to like new. http://hrclutch.com
Mike
