6 members (Gdads51, stlcardinalsguy, Ponchogl, tomctomc, Bill Hanlon, 55shaker), 110 guests, and 1 robot.
Topics128,054
Posts1,055,782
#1291945 12/21/2018 11:34 PM
My question concerns brake backing plate, since the bleeder screws are so close to the spring stack, could the plate be turned one bolt hole to mount new brake cylinders ? It is the only way to bleed the brakes on my ton truck that I know of, thanks Pat?
1966 Chevy C 30 1 ton truck
Riding in the Passing Lane
I don't know what you mean by "turning one bolt hole" but you can take out the bolts that hold the backing plate on & service the wheel cylinder & bleed it. If you don't let the master cyl. run low all the air will be right at the cyl. You can put a C clamp on the cyl. to keep it from coming apart while you bleed it.
George
1972 Chevy c10 Cheyenne Super
Bleeder screw needs to be at the top to remove all the air, which it is in original configuration. Turning backing plate 90* likely traps air.
1952 Chevrolet 3800 pickup
---All pictures---
Thank you for the advice. Pat
Moderated by  Dusty53
