0 members (), 160 guests, and 5 robots.
Topics128,149
Posts1,056,818
Members48,456
#129180 06/05/2002 6:35 PM
Junior Member
Junior Member
Hi I have 46 Chevy ¾ ton truck I would like some info on improving the brakes. like disks brakes. or the stock setup I remember someone did the disk brake stuff, but don’t remember ware I seen it. grin
Gary Cook
http://www.stovebolt.com/truck/techtips/discbrakes.htm
'This may help.I found it for you in the tech-Tips area of the stovebolt.
Junior Member
Junior Member
Like I said in the lounge, I used 4x4 discs (eight lug) and bolted them to the hub where the drums used to be bolted. I made caliper mounts out of plate steel. I have not used this setup yet. Hopefully it works. Good luck.
