| | | Forums66 Topics128,154 Posts1,056,850 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2002 Posts: 1 Junior Member | | Junior Member Joined: Jun 2002 Posts: 1 | Hi I have 46 Chevy ¾ ton truck I would like some info on improving the brakes. like disks brakes. or the stock setup I remember someone did the disk brake stuff, but don’t remember ware I seen it. Thanks Gary Cook | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | http://www.stovebolt.com/truck/techtips/discbrakes.htm . . 'This may help.I found it for you in the tech-Tips area of the stovebolt.
| | | | | Joined: Jul 2001 Posts: 19 Junior Member | | Junior Member Joined: Jul 2001 Posts: 19 | Like I said in the lounge, I used 4x4 discs (eight lug) and bolted them to the hub where the drums used to be bolted. I made caliper mounts out of plate steel. I have not used this setup yet. Hopefully it works. Good luck. | | |
