10 members (JW51, Gdads51, dt235sd, Gray_Ghost, Woodcmiami, Shaffer's1950, Nick in Manitou, 3 invisible), 71 guests, and 3 robots.
Topics128,131
Posts1,056,372
Members48,441
Found this today
No badges, looks like s 61
It has 10 lug 19.5. The rear axle looks bigger than the Eaton ones I have seen on 8 lug trucks. Straight 6 4spd. Has a governor under the carb
Thinking about a stockish shop truck
I hit cars with hammers
Was wondering what the difference was between a c30 and c40
3B Offline
Hy Anthony Myrick, if it has ten bolt wheels, it is at least a 40 series, hope that helps, Merry Christmas!
Thanks. Never even heard of a c40 until today.
Going to get a pic of the vin soon and check the gvw
Right, looks like a C-40 with the Emblems missing.
Check the GVW. It should be about 14,000.
In '60, '61 and '62, the C-40 was like a heavy C-30 and looked very similar.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
That’s what I was thinking after locating a 61 service manual online
A 14k gvw would be perfect for a ramp truck or just a cool flatbed to use around the shop
I generally hot rod and lower things but think I may leave this one alone
I have a c60 that I was planning on building a ramp truck for hauling cars with but I think this ones ride height would help that be a lot easier
I like this. Would probably have to lengthen the wheel base a little
Would make a nice Ramp or Rollback. Check out the wheels though. I'm not real familiar with the type that were on those trucks, but they could be an unsafe kind. Before you restore it, see what you can find for replacements.
GMC 9500 Fan
Detroit Diesel Fan
10 lug 1 piece 19.5
Should be fine.
looking up brake parts
looks like this one shares parts with c30 and c50
the parts stores do not list the c40
this one is gonna be fun looking up parts
Truck has a 14k gvw and a 157 inch wheelbase
That should make it a C40.
Checking out to see if 10 lug discs can be used on it
