0 members (),
136
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2014 Posts: 70 'Bolter | | 'Bolter Joined: Nov 2014 Posts: 70 | I have 2 different mono-jet cores and 1 of which by the ID # was a governor carburetor. The governor is long gone, so without the governor will it work correctly or was there some changes made to the internals to work in conjunction with the governor?
ESum
| | | | | Joined: Feb 2016 Posts: 1,989 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,989 | All of the governors I've seen have been external and effect the throttle linkage or throttle shaft. If you can operate the throttle by hand and the butterfly opens and closes then your on the way to a useful carb. You may be able to modify it to suit your needs. Internals should not be any different than non-governor. The governors I have worked on are spring loaded, a small spring works to open the throttle and the throttle linkage allows it to open, vacuum opposes the spring.
ESum
