5 members (baldeagle, Wayne67vert, klhansen, Joe H, Gray_Ghost), 92 guests, and 9 robots.
Topics128,019
Posts1,055,343
Members48,419
#1290762 12/12/2018 6:45 AM
I removed the clearance lights the other day. The ambler glass in all three lights is perfect. The upper housing that holds the glass down is rusty but salvageable. The lower metal base and rubber gasket are destroyed. Any recommendations to fix?
Big Bolt Forum Moderator
What are you working on? a picture of the lights might help as well!
Mike
Fitzy440 #1290772 12/12/2018 12:54 PM
Find the model light and many times you can find them NOS if you search.
I’ve found several sets of new but old KD 517 lights for my trucks, they look the nicest in my opinion, and have glass lenses.
1952 Chevrolet 3800 pickup
---All pictures---
I've always liked the look of AD trucks with clearance lights. Anyhow, I haven't found any that I really like though, except for the KD 517 like Grigg stated. Most aftermarket are cheap plastic ones.
I have came across some motorcycle fender lights that look like they would fit the bill. The roof of our cabs being curved like a fender, they may just work.
Drag Specialties
Sidecar
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
I really like the clearance lights. It would be nice to keep them on the truck.
Looks like KD517
---All pictures---
Looks like the 517 lights are golden on eBay. I find some guys using Grote 45333 lights. They’re slightly shorter, but have a similar look.
"The Fake Truck"
V
VEW Offline
V Offline
I have those lights on the bus. Yours actually look pretty good compared to mine! I've spend some time trying to find parts, but no luck. I concluded the bases would need to be fabricated.
Good luck with them. I do like them and they are still on the bus. I do have some spares that I've collected, but again, the bases are needed.
~ Victor
1957 3100 - moved on
[quote]I really like the clearance lights. It would be nice to keep them on the truck./quote]
Your lights look like they could be restored. Start with a soda blast to clean all the rust, then fill pits with body putty sand and prime. Use JB Weld to fill rust holes. You could cut new gaskets from sheet rubber. You can buy inside of the light socket from almost any parts store or pull from another socket.
Harold
Harold
The Arrow No. 39 is a close second! They can be found NOS in the box...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
