| | | Forums66 Topics128,012 Posts1,055,318 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 90 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 90 | Has anyone out there used something other than a sbc or ls in their restomod or ratrod 47-55 AD with an S10 or custom frame? And I don't mean something like a 4.3 v-6. I'm talking like a 6.2 or 6.5 diesel or even a Duramax. And since I have a soft spot for Pontiacs, what about a 389 or 400?
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Modern Diesels are really too heavy for an S-10 frame, 6.2 or 6.5 would be marginal.
ED
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Whatever BB or Diesel you decide will be a plan, fab and mock up exercise. Does not matter what "body" goes on the Custom or S10 frame. The basic work will be the same. Design Rube as you go.
52Carl makes a lot of Mad Max Rebel War Wagons like that. Check him out.
I like to keep 'em near original.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Feb 2005 Posts: 90 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 90 | The Duramax idea came from a video I saw on YouTube. Guy put one in a ‘66-67 nova station wagon. Don’t know any of the details but the guy made it fit. Just ideas right. Nothing definite. Thanks for the replies. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | The 4.3 V6 weighs 425# and the Duramax 835# so you have 400#'s more weight but since it is a truck the front suspension is designed to handle load weight in the bed. If the IFS is from a single cab long bed S10 the max load in bed was probably around 1500#'s which added at least 500#'s onto the front end when bed loaded which is in the design range if no load at all in the bed. Although it may handle the extra weight it will drive like a pig since the front to rear weight ratio will be at least 75/25---helpless on any road with less than ideal traction. My 76 LUV with a 400 sbc was completely helpless if it rained.
Evan
