7 members (tclederman, Gdads51, 1955 1 Series, moparguy, Gray_Ghost, Otto Skorzeny, 1 invisible),
75
10
Mod | | | Forums66 Topics128,078 Posts1,056,027 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2000 Posts: 2 Member | | Member Joined: Dec 2000 Posts: 2 | How closley matched are the cabs for the trucks from 1939-40 till 47? I am trying to install a newer style brake cylinder on the firewall and have a set of instructions for a 47 1/2 ton but would like to know if the "ribs" and seams are even closely matched? Any idea's out there? | | | | | Joined: Jun 2001 Posts: 379 Shop Shark | | Shop Shark Joined: Jun 2001 Posts: 379 | Believe confusion begins with the mid-year design change in '47. Quite a different truck than the Wurlitzers... | | | | | Joined: Feb 2001 Posts: 96 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 96 | When I mounted the power booster on my 46 I made a doubler. Then I had to put a piece of angle alum on each side of the swing pedal bracket and then a piece of flat stock back to the dash from the top of the bracket to keep the firewall from flexing. | | | | | Joined: Apr 2000 Posts: 58 Member | | Member Joined: Apr 2000 Posts: 58 | besides a bracket to the dash, a large piece of 1/4" plate on the inside of the firewall will stiffen it considerably. | | |
