| | | Forums66 Topics128,118 Posts1,056,305 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2018 Posts: 59 Chief Bottle Washer | | Chief Bottle Washer Joined: Oct 2018 Posts: 59 | Hi Gang,
Is my truck a Positive or Negative ground?
All original...1952 3100, 6-volt, 216 cu in.
I can turn a wrench, but have no mental concept for anything electrical. I have done due-diligence trying to find an answer here, and on other sites, but am getting a lot of conflicting information. I really wish the answer could be posted on SB's "Tech Tips" link...
Cheers,
Jim | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Chevy is Negative ground.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Chevy is Negative ground. Which means the cable attached to the negative post on your battery goes to the motor or the frame or the body. The positive cable goes to the appropriate starter lug. I guess it's so understood that it's not a tip. Sure like to know what conflicting info you are talking about. GMC, not to be confused with the company called GM who made them, had positive ground trucks for a while. Chevrolet trucks with Chevrolet motors, also a part of the company GM, used negative ground. Just to test a web search, which I recommend, I googled "Chevrolet positive ground" and the first entry gives the answer. It is possible for someone to convert to positive ground or hook up a battery wrong and the new owner can get confused.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | i'm curious now what would happen if you swapped it to positive ground by mistake... you would be able to start the engine, all the lights would be find but... the generator and amp meter wouldn't like it much at all, that might lead to a damaged regulator and amp meter
the gas gauge should probably read okay -s | | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | Lights and starter won't care. The ignition and charging systems will have a few problems, possibly including stuck cutout relay points in the regulator if a DC generator is installed. If the vehicle is equipped with an alternator there will be an immediate dead short that will fry the alternator and possibly set the wiring harness on fire. Jerry
| | | | | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | I did a 12 volt conversion on a 55 T-Bird a few years ago. Prior to the conversion the owner had the cables switched as he didn't have any knowledge of the differences in vehicles that used 6 volt systems. All he had ever seen were late model cars with 12 volts. I recall it did run but I believe he had it towed home a lot. It performed great with the 12 volt conversion and using a 10SI alternator. Fred
| | | | | Joined: Oct 2018 Posts: 59 Chief Bottle Washer | | Chief Bottle Washer Joined: Oct 2018 Posts: 59 | Thanks everyone, you've bailed me out one more time!
Jim | | |
