7 members (Otto Skorzeny, Phak1, TUTS 59, Hotrod Lincoln, Gray_Ghost, Crimson48, 1 invisible),
134
Mod | | | Forums66 Topics128,080 Posts1,056,063 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 58 hmmm. | | hmmm. Joined: Sep 2011 Posts: 58 | The new "Retrosound" digital radio fits great in the 49' 3600. The main problem is that the light for the readout works once in awhile. Somewhere in my memory I recall someone stating to remedy this incompatibility between old and new electronics is to install a capacitor, or some figamajig. So, the radio operates good, except the light that illuminates the screen sometimes works... It has been off for weeks. I know the fix to this is out there is out there someplace. Thank you.
il | | | | | Joined: Sep 2011 Posts: 58 hmmm. | | hmmm. Joined: Sep 2011 Posts: 58 | So here it is nearly Dec. and I have found a lead on this issue. Apperrently 'old cars and trucks' electricall systems produce energy spikes. These can mess up new radios in old vehicles. I am thinking in terms of a surge, so a surge protector ought to be the clue to the figamagig I need to install. So now, whatever that is ... Meanwhile Retrosound says they can fix it. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If it works once in a while, it is not damaged, it is defective. All the old car radios had a filter of sorts on the input power to guard against spikes. | | | | | Joined: Sep 2011 Posts: 58 hmmm. | | hmmm. Joined: Sep 2011 Posts: 58 | You would think manufacturers would include some sort of surge protector. I am getting a RA now. | | | | | Joined: Sep 2011 Posts: 58 hmmm. | | hmmm. Joined: Sep 2011 Posts: 58 | I have had a great experience with the radio manufacturers. They replaced the radio I had and gave an upgraded one to me. What a great way to run a business. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | That is good news and it is nice to see that they took care of you. . | | | | | Joined: Sep 2011 Posts: 58 hmmm. | | hmmm. Joined: Sep 2011 Posts: 58 | meanwhile, I put a 10 amp fuse in and I grounded the alternator to the engine block. | | |
