| | | Forums66 Topics128,282 Posts1,058,495 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2017 Posts: 120 'Bolter | | 'Bolter Joined: Jun 2017 Posts: 120 | I have a 54 3100 with a new windshield and Steele rubber seal that refuses to to seat on the pinch weld on both vertical pillars, right and left. Is there something I am doing wrong, I would say it is a about 1/4" proud of where it should be.
Is it junk glass that was not formed properly?
Anyone else having the same issues, the glass has been in and out of th truck at least 5 times.
Also, are there any american manufactures that still make these?
Thanks for any help
| | | | | Joined: Mar 2013 Posts: 186 'Bolter | | 'Bolter Joined: Mar 2013 Posts: 186 | How are you putting the glass in? | | | | | Joined: Jun 2017 Posts: 120 'Bolter | | 'Bolter Joined: Jun 2017 Posts: 120 | rubber seal and glass go into opening, use a rope cord to bring the lip of the rubber over the pinch weld until it gets hung up on the sides and wont go in any further. | | | | | Joined: May 2017 Posts: 100 'Bolter | | 'Bolter Joined: May 2017 Posts: 100 | Apply soapy water. and have second person flat palm slap the glass.To start glass in. More soapy water ect. It will go in
!956 Gmc Napco 4x4 Factory line built .
| | | | | Joined: Mar 2010 Posts: 10,336 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,336 | The pros hit the glass with the palm of their hand so hard that it is unbearable to watch. They do it in a very progressive way as the glass begins to go. They also hit the glass on an angle to force the glass to go in a lateral direction. The guy that I use told me that if the glass breaks, its on me. He has not broken any of mine yet.
| | | | | Joined: Jul 2018 Posts: 8 'Bolter | | 'Bolter Joined: Jul 2018 Posts: 8 | I have a 55.1 and went through this nightmare a few months ago. The problem is likely that your bottom pinch weld got bent out when the old windshield was removed. Stick your head in the windshield opening from inside the cab and look down at the bottom pinch weld. Look for high spots and gently tap them back down (towards the inside of the cab). Check the top too. Little movements make a big difference.
I did this on mine and eventually the sides just fell into place. You shouldn’t have to beat on it.
1955 Chevy First Series 3100 1955 Chevy 210 Sport Coupe
| | | | | Joined: Jun 2017 Posts: 120 'Bolter | | 'Bolter Joined: Jun 2017 Posts: 120 | All those ideas sound good but when I pull back the outer lip of the Gasket from the outside you can see the areas of the seal with the small linear ribs binding on frame of the window.
Hope this makes sense and thanks for your comments. | | | | | Joined: Jul 2018 Posts: 8 'Bolter | | 'Bolter Joined: Jul 2018 Posts: 8 | This is the exact problem I had. Bending the bottom pinch weld flange back towards the cab allowed the whole windshield and gasket to sit back into the cavity, pulling the sides in too.
| | | | | Joined: Nov 2012 Posts: 263 Haunting the SBP since 2001 | | Haunting the SBP since 2001 Joined: Nov 2012 Posts: 263 | It has been my experience that the Steele rubber is produced to exacting precision original OEM specifications.
Not so much with virtually every piece of new reproduction glass I have run across.
Most re-pop glass arrives with slightly larger dimensions than the original glass. { which is the result of trying to transfer original glass dimensions to a new pattern. }
I would not put the blame of an ill fitting gasket on Steele Rubber because their gasket does not fit an improperly sized piece of glass.
| | | | | Joined: Jun 2017 Posts: 120 'Bolter | | 'Bolter Joined: Jun 2017 Posts: 120 | I believe that I agree on maybe glass size and how it’s formed on either end. Seems to lack the proper forming (not enough). | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Measuring and cutting equipment has a certain built in margin of error. Most manufacturers try to allow for proper fitment but obviously some don't. Steele is expensive but they do care about how their product performs. Hang in there posey, you will get this.
| | | | | Joined: Mar 2016 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2016 Posts: 28 | If you had the original windshield you could lay the new one overtop to verify the curvature into the A pillars is correct. Without that you'll never know, but if you're 1/4" proud at the pillars your only solution is to work the upper and lower pinch welds so the entire glass moves 1/4" deeper into the cab. You can't re-shape the glass, so you have to re-shape the opening. | | | | | Joined: Jul 2018 Posts: 8 'Bolter | | 'Bolter Joined: Jul 2018 Posts: 8 | If you had the original windshield you could lay the new one overtop to verify the curvature into the A pillars is correct. Without that you'll never know, but if you're 1/4" proud at the pillars your only solution is to work the upper and lower pinch welds so the entire glass moves 1/4" deeper into the cab. You can't re-shape the glass, so you have to re-shape the opening. This is what fixed mine.
| | | | | Joined: Mar 2010 Posts: 10,336 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,336 | You can reshape the glass with a belt sander I have heard. A local glass company can do it if you are scared.
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Emery cloth will cut glass, get an emery cloth belt.
Ed
| | | | | Joined: Dec 2017 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2017 Posts: 28 | When I worked at a glass shop we used a wet belt sander to bevel the edges of coffee tables, mirrors, etc. I would just recommend keeping it cool if you use a belt sander.
55 3800 | | |
