6 members (rfs56trk, wilbur53, dt235sd, J Lucas, JoergK., Bill Hanlon), 84 guests, and 2 robots.
Topics128,205
Posts1,057,427
Members48,471
With above setup which is new I feel the engine rpm’s are ver high before shifting into 2nd OD. Any idea what it should be?? Know OD is supposed to kick in around 28mph in 2nd.
What transmission?
Actually the OD will kick in at 28 mph in ANY forward gear. This is the speed at which the governor activates and sends current to the solenoid. The solenoid will stay engaged till speed is less than 28 mph so if 2nd gear high rpms bother you just shift into high gear before engaging the OD. Once in OD you can shift back down into 2nd gear and still be in OD if you have a need for 2nd over. With 3.90 rear the final drive in OD will be 2.73---a great road gear.
Evan
H Online: Content
Is there some pressing reason for using OD in 2nd. gear? I'm assuming you're talking about a Borg-warner OD on a 3 speed? If you run fast enough in 2nd. to let the OD engage, you'll have to use the kickdown to get back into 3rd. gear direct drive after you shift. I can't imagine a need to use OD in second gear in the first place.
