9 members (TooMany2count, Opelika Tom, Otto Skorzeny, 78buckshot, TrknGMC, Charles in CA, MikeE, Wayne67vert, TexasA&M48Truck),
59
0
Mod | | | Forums66 Topics128,091 Posts1,056,037 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Well I don't have one of those trucks. We have all have had plenty of rusted bolts and screws that just will not come off. I have used all kinds of methods. I don't like the drill the head method but I do it sometimes. You keep talking about going to a shop. If you have money for that, just buy some tools. You can't keep going to a shop for this mundane typical restoration stuff. They will charge a lot for that job. I offer some observations, experience and suggestions to ponder and build upon. I love this kind of problem but it's hard to come up with a good suggestion when I can't see the back side of hood. I've looked at used emblems for sale on Ebay to get an idea of its structure and mounting.
1. Get a 4 1/2" electric angle grinder. Kevin's suggestion. Too bad you can't get a compressor and a die grinder. That would be the best tool. Smaller but powerful. 2. Get some goggles and gloves. 3. Get brave. 4. It seems like pictures I see show that the emblem has threads and the screw must go thru a bracket into the emblem threads from behind. Instead of drilling head, I usually cut a cross in it with a die grinder and just kiss the part that the head is against. Center of cross is center of screw head. Then a small chisel and a small hammer will snap off the four sections. This leaves me maximum shank to grab for the slow back and forth after PB Blaster soak if I'm saving the female threads. In your case you are not trying to save any threads if I see this correctly. If you can not access the screw heads holding the emblem on, see 4a or equivalent. 4a. Attack from the front side leaving four 1" squares or the "clips" at screw attachments. Most of emblem will be gone at that point and visual and tool access will be enhanced. Then proceed to cut off the squares and cut off the shank/clips and withdraw screw from rear. The 4 1/2" angle grinder is a manly tool, high speed, very sparky and dangerous if you do not take control of it with conviction. It's also fun to blast everything that won't come loose. Just don't cut the hood in half. Don't spark near gas or glass or flammables or people. I recomended the angle grinder because you said you have no air and you need something that will work at a reasonable price. I have a Harbor Freight one and a Ridgid one. Use a 1/16 thick cut off disc for this. When you use it to actually grind something, you will use a thick disc.
If I don't see this emblem attachment properly, please someone correct me....or supplement my brainstorming.
No offence to Dusty but the video is not even close to what we are taking about when drilling a head off as Kevin said. Note to Kevin: Why are you needing to hold the head with vice grips? If it spins, it breaks off or the whole screw is tightening? If the screw is not threaded into threads on the emblem, my question is moot.
No offence to Brad but I have never found a dremel to be robust enough for this kind of job and the "bits" wear out too fast.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Im with Bartamos. Attack it from the front,, cut into the emblem and expose the points that hold it on. ( per Brad Allens picture). Its a matter of using your imagineering and being smarter than what youre working against. The 4" angle grinder with different wheels will be an invaluable tool during a self restoration. Dont forget the safety glasses, After 5 pages of questions and answers, its time to get past this 15 minute job. Good Luck, | | | | | Joined: Mar 2007 Posts: 200 'Bolter | | 'Bolter Joined: Mar 2007 Posts: 200 | Thank you guys for all of your help. I do understand about cutting it off. I just didn't want to rush into cutting up my truck, so yes - I am reluctant. Sorry it's a 5 minute job for you but it's not for me. This is the "Discussion Area" and that's what we were having , until now. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | No problem Tom. Re-post or PM if you need anything else. It's not a 5 minute job. You are not cutting up your truck, you are cutting the emblem or a screw head. Those fellows are not usually rude. They are good people. You will learn that we all get testy/impatient sometimes. I do many times.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Mar 2007 Posts: 200 'Bolter | | 'Bolter Joined: Mar 2007 Posts: 200 | | | | | | Joined: May 2015 Posts: 11,055 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,055 | Note to Kevin: Why are you needing to hold the head with vice grips? If it spins, it breaks off or the whole screw is tightening? If the screw is not threaded into threads on the emblem, my question is moot. Bartamos, Tom started out asking about how to get the hood latch panel out to get to the screws holding the emblem on. The emblem is just fastened thru the hood outer sheet metal with screws from the back side into female threads on the emblem. I initially thought that all those pieces, (rod style braces and hood latch panel) had flat head screws and nuts, so when drilling off the head, at times, the whole thing will spin in the hole and you'll either need to hold on to the screw head or the nut so the drill will bite and get the head loose from the screw shank. I'll admit that drilling out a head doesn't always work. Tom, I'd recommend a 3" cutoff tool with a 1/16" disk to go thru the front of the emblem. Never fear, you'll get 'er done.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Understood Kevin.
There are many things I have not done before and I get my gumption from here and the web. It always works out.
