5 members (Peggy M, Hanks custodian, Dennys28, 2 invisible), 86 guests, and 3 robots.
Topics128,059
Posts1,055,818
#1288302 11/21/2018 5:51 PM
Hi, I owned a 50 Chevy 3-window, half-ton,shortbed pickup truck and it had a goldish-color / brass colored shiny radiator top. Did all of these or similar trucks come with this kind of radiator?
Radiators were painted black.
It might be a reconditioned or replacement radiator?
Was there brass material under the black paint?? Has anyone ever taken off the paint - and what did you find?
Does anyone else have brass-top radiators in their 47-53 Chev half-ton trucks?
The stock radiator for the 47-53 was a Harrison Radiator ( a division of General Motors).
They had brass alloy tops. In the Korean War years, ca1951 , brass was critical for the war effort and Chevy did briefly uses a ferrous alloy radiator top. It rusted quickly and needed to be dealer replaced.
Regardless both versions of the radiator had a black coating to prevent corrosion.
I believe the "black paint" could have been a carbon black and shellac-like mixture, not what we commonly think today as "paint",but black paint-like none the less ...
Hi, what is a "ferrous alloy"?
How can I take off the "black carbon mixture" to see the brass shine through?
Big Bolt Forum Moderator
you should be able to clean the "paint" off with something like Lacquer thinner.(assuming it is out of the vehicle). You may need to use a scuff pad as well (like scotchbrite or steel wool). Once you do that, you will need to polish it to make it shiny and get rid of the scratches. Polished brass will tarnish real quickly though.
Mike
The radiator is still in the vehicle and works well. I do Not want to take it out of the vehicle...
Can I still use your method 69cuda if it's in the vehicle?
just don't drip the thinner on anything painted!
Mike
Ex Hall Monitor
Ex Hall Monitor
A ferrous metal attracts a magnet. It normally rusts when exposed to air and moisture. Think iron and steel. It's usually referred to as ferromagnetic.
Oh, ok - I see 69Cuda. Thank you! And Tiny - Thank you for the info!
Ferrous = iron. Comes from the symbol for iron, which is "Fe". So a ferrous alloy would be steel or at least something with iron in it.
[on edit] I see I'm late to the party. blush
However, stainless steel is a ferrous alloy as well, so resistant to moisture caused corrosion.
Ex Hall Monitor
Ex Hall Monitor
Some stainless is magnetic depending on the alloy.
Thanks guys - Happy Thanksgiving everyone!
