| | | Forums66 Topics128,110 Posts1,056,255 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2016 Posts: 182 'Bolter | | 'Bolter Joined: Jun 2016 Posts: 182 | A little help please. Does the ignition switch wire connect to the positive or negative side of the coil? Tkx | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | + to the switch. - to the points. The coil will work wired backwards, but, not as well. The windings in the coil are insulated from the can outside. So it will not short out. The coil is wound in a manner that reversing the current flow may reduce the output voltage(efficency) . That is an "Engineer" convesation that we can avoid. The last conversation I got stuck in like that was about "hole flow". Look it up if you need to. Still makes my headake after 50 years.
Steve H
| | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | That’s interesting Steve. I never knew it made a difference which side the ignition was wired to. I learned something today!
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: Feb 2004 Posts: 29,803 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,803 | Just to muddy the waters a little more- - - - -the real culprit to reversed coil polarity is "inductive reactance"- - - -the resistance to current flow in the primary coil winding if the end of the secondary coil winding is at the distributor side instead of the ignition switch side. LOL! Jerry
| | | | | Joined: Jan 2018 Posts: 189 'Bolter | | 'Bolter Joined: Jan 2018 Posts: 189 | I've never thought about too much coil polarity. Just hooked it up the way it was supposed to be. I got curious and wondered why? Stumbled on this, and now it makes sense. Tesla would have known that for sure too. http://mgaguru.com/mgtech/ignition/ig104.htm
| | | | | Joined: Jul 2000 Posts: 2,193 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,193 | Thanks 4100. Inquiring minds like to know!
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | |
