Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (crenwelge), 151 guests, and 2 robots.
Topics128,281
Posts1,058,465
Members48,490
A little help. I am going to install the resistor block on my truck. But forgot where it goes. The new one has two terminals. What connects to each terminal? Also where does it attach to the engine or firewall? Fix
H Online: Content
Is your truck converted to a 12 volt electrical system? If it's still 6 volt, you don't need a resistor. The resistor is used on a 12V system to drop the battery voltage to around 9 volts during normal running to prevent the points from burning. It's wired between the ignition switch and the coil (+) terminal, and it can be mounted anywhere on the firewall that's convenient, or even on the bracket that holds the coil onto the cylinder head. Putting it somewhere it can get airflow from the fan helps to keep it cool.
Bolted mine on the firewall and it still caused the immediate paint to heat up and flake off. It needs better air flow.
Craig
