7 members (cmayna, Deegs53, ShopRag, dt235sd, Otto Skorzeny, 2 invisible), 183 guests, and 2 robots.
Topics128,260
Posts1,058,087
Members48,482
#1287854 11/17/2018 5:21 PM
I have two wires coming out of the back of my radio. One red and one green. I am assuming the red one is power and is connected to the light switch. What is green one and where does it go? Any help is appreciated. Thanks
I don't know if this is an original type radio but the original radio had a thinner wire for the dial light and a thicker one with a fuse holder for the main power to the radio.
1951 1 Ton Completed
Want to install a new radio in my 52 GMC , all that is available is 12 volt and truck is 6 volt , can I change 12 volt to 6 volt ?
marine1964,
it would be better for you to start a new thread of your own when you have a different question. However I will give an answer here. There are small power supplies that you can buy that will provide 12 volts Dc from 6 V Dc. However, if your GMC has a positive ground setup, finding a power supply to do the job might be difficult. In that case I would suggest converting the truck to a negative ground system.
old Mack trucks and some jaguars has positive grounds.
https://www.ecklers.com/power-inverter-positive-to-negative-ground-6-to-12-volt-1-3-4-cube-3-5-to-5-amps-output-28-20693-1.html?T5_Var4=28-20693-1&srsltid=AR57-fCyvn9EwzgrIgwq-qR9hStoydOarNXjsEWpvDUnaZF7t9WtkoK6_A8&utm_content=Electronics%7CCustom+Autosound
1960 Chevy C10 gasser- Rabble Rouser
1953 Harley Davidson Panhead chopper
Goooogle "6 volt positive ground to 12 volt negative ground" and you'll find a bunch of devices designed to solve this problem.
Moderated by  truckernix
