3 members (UtahYork, Millenimech, klhansen), 168 guests, and 1 robot.
Topics128,115
Posts1,056,289
Members48,439
Apprentice
Apprentice
Hi,
I am putting my truck together from parts so I don't have a complete truck to look at for reference. So......the rear upper mounts for the front fenders (on the cab) are in a bad state of repair. Can someone tell me if they are bolts or nuts encapsulted to allow for movement (alignment)? Can someone point me to a few pics and/or a listing of where I can buy them or how to repair them?
Carl
CCB
Just my 2 cents but for me, reassembling with out reference books would be like trying to work a puzzle blindfolded. Two books you might want to pick up are:
• Chevy Truck Shop Manual
• Chevy Truck Factory Assembly Manual
Plenty of pictures...
~Jim
you can't buy replacements for those mounts - get the assembly manual, look at the pics, build a 'tower' with a nut welded in the center, hope ya get it right - they have no movement, position is all
If you are rebuilding it from nothing, it wouldn't hurt to make captive nuts that allow for some movement, then you can fit it up a lot easier.
Paint & Body Shop moderator
Apprentice
Apprentice
4onthefloor,
Creating a capsulated nut was what I had in mind, but I wasn't sure what was in there originally. I'll give it a try and post the results when I finish!
Thanks for the input guys!
Carl
CCB
LMC now sells the cowl cheeks with that mount in place
about 4-5 months ago I asked the same question you are asking and Lane Fotty-a Stovebolter responded by saying he had two if I wanted them. Talk about a random act of kindness! What a guy. These were the 58-59 style(round) as apposed to the 55-56 style square. Just welded them on this past Sat. I have a stamping background and toyed with tooling these mounts up...but I'm not sure the demand is there...so I went back to being a slacker. If I was going ro make one..I found just the right size freeze plug that made a nice tower...drill a hole..weld a nut ...viola! As mentioned above, placement is everything.
Keith
