2 members (46 Texaco, sron48),
146
0
Mod | | | Forums66 Topics128,119 Posts1,056,313 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 23 Apprentice | | Apprentice Joined: Sep 2006 Posts: 23 | Hi, I am putting my truck together from parts so I don't have a complete truck to look at for reference. So......the rear upper mounts for the front fenders (on the cab) are in a bad state of repair. Can someone tell me if they are bolts or nuts encapsulted to allow for movement (alignment)? Can someone point me to a few pics and/or a listing of where I can buy them or how to repair them? Carl
CCB
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Just my 2 cents but for me, reassembling with out reference books would be like trying to work a puzzle blindfolded. Two books you might want to pick up are: • Chevy Truck Shop Manual • Chevy Truck Factory Assembly Manual Plenty of pictures...
~Jim
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | you can't buy replacements for those mounts - get the assembly manual, look at the pics, build a 'tower' with a nut welded in the center, hope ya get it right - they have no movement, position is all
Bill | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | If you are rebuilding it from nothing, it wouldn't hurt to make captive nuts that allow for some movement, then you can fit it up a lot easier.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Sep 2006 Posts: 23 Apprentice | | Apprentice Joined: Sep 2006 Posts: 23 | 4onthefloor, Creating a capsulated nut was what I had in mind, but I wasn't sure what was in there originally. I'll give it a try and post the results when I finish! Thanks for the input guys! Carl
CCB
| | | | | Joined: Jan 2007 Posts: 615 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 615 | LMC now sells the cowl cheeks with that mount in place
about 4-5 months ago I asked the same question you are asking and Lane Fotty-a Stovebolter responded by saying he had two if I wanted them. Talk about a random act of kindness! What a guy. These were the 58-59 style(round) as apposed to the 55-56 style square. Just welded them on this past Sat. I have a stamping background and toyed with tooling these mounts up...but I'm not sure the demand is there...so I went back to being a slacker. If I was going ro make one..I found just the right size freeze plug that made a nice tower...drill a hole..weld a nut ...viola! As mentioned above, placement is everything.
Keith | | |
